Choosing the Right Screwdriver Bit
  1. Choosing the Right Screwdriver Bit, Identification: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Choosing the Right Screwdriver Bit, Identification: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The screw bits in our iFixit bit kits have engraved prefixes that indicate the head type. These prefixes are typically followed by a number that indicates bit size. For example:
    • PH2 - (Phillips #2) A large Phillips bit.
    • PH0 - (Phillips #0) A medium Phillips bit.
    • PH000 - (Phillips #000) A small Phillips bit.
    • Choose the bit size that fills the screw head entirely. A bit that is too big or too small will not seat properly, and you'll end up with a stripped screw.
  2. Choosing the Right Screwdriver Bit: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Choosing the Right Screwdriver Bit: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you find yourself scratching your head over identifying the bits in your tool kit, feel free to use this reference list.
    • Physical bit shape followed by proper name.
    • Bit size.
    • If there is no prefix engraved in your bit, simply use the full proper name and size when using your bit in a guide. (For example: "Use a 1.5 mm Flathead bit to remove the two 5 mm case screws.")
  3. Choosing the Right Screwdriver Bit, PH vs JIS: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Choosing the Right Screwdriver Bit, PH vs JIS: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Phillips #1 Screwdriver
    $5.49
    • Bits with the prefix "J" and "PH" are often thought to be the same bit. Don't be fooled by their similar appearance—they are quite different.
    • Phillips (PH) screws are designed to make a Phillips screwdriver cam out if too much torque is applied. This prevents damage to screws and screwdrivers or bits.
    • Japanese Industrial Standard (J) screws do not provide a cam-out option, and have 90 degree corners.
    • J (or JIS) and PH (Phillips) driver bits are not always interchangeable. As you can see, they do not share identical physical properties.
crwdns2935229:0189crwdne2935229:0
Richard
crwdns2935283:002/07/17crwdne2935283:0
33 768 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
crwdns2947412:024crwdne2947412:0
Excellent guide. could not figure out the difference by looking.
Lawrence Steinheuer-Turner - crwdns2934203:0crwdne2934203:0
It would be clearer if the displayed drawing of each bit actually said J-bit or PH-bit, and because both have 90 degree corners, maybe change the J-bit description to “have 90 degree square inside corners“ and include in the PH description “have 90 degree rounded inside corners.
Otherwise, with interpretation, your article helped me.
Phil - crwdns2934203:0crwdne2934203:0
what size hex shaft do these smaller bits have?. i have an electric precision screw driver, for electronics. i go through the PH1 bits very quickly. i can NOT find them for sale anywhere on earth. does anybody know where to purchase these things?? and/or tell me how i should word the query. all im getting is 1/4 hex shaft results. very frustrating
brett everett - crwdns2934203:0crwdne2934203:0
4mm bit size
Anthony Cole -
Ifixit warranty covers replacement bits
Just message their support email
Ash -
crwdns2936751:024crwdne2936751:0 109
crwdns2936753:07crwdne2936753:0 710
crwdns2936753:030crwdne2936753:0 3,128
crwdns2942667:0crwdne2942667:0 293,211
