Chevy 305 Engine Main Bearings Replacement
  1. Chevy 305 Engine Main Bearings Replacement, Main Bearings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chevy 305 Engine Main Bearings Replacement, Main Bearings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 18 bolts holding the oil pan in place (fourteen ⅜” bolts & four ½” bolts on each corner) and remove oil pan using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Main Bearings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 main bearing caps.
    • Three caps with four ⅝ bolts and two caps with two ⅝ bolts at the front and rear of crankshaft.
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
    • DO NOT SWAP THE LOCATIONS OR DIRECTIONS OF THE CAPS.
  3. Chevy 305 Engine Main Bearings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace main bearings.
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
    • Gently tap the cap against the engine block or use a thin flathead to remove.
  4. Chevy 305 Engine Main Bearings Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the main bearing caps back.
    • Three caps with four ⅝ bolts and two caps with two ⅝ bolts at the front and rear of crankshaft and torque to specs. (65 ft.-lbs.)
    • Do not swap the locations or directions of the caps during reinstallation. (reverse of removal)
  5. Chevy 305 Engine Main Bearings Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chevy 305 Engine Main Bearings Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the oil pan gasket.
    • Use a razor blade, flathead screwdriver or putty knife to clean up the old gasket and wipe down where the old gasket was with brake cleaner and paper towels before placing a new gasket.
    • Be careful not to drop any gasket debris into the engine.
  6. Chevy 305 Engine Main Bearings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the oil pan back into place.
    • Fourteen ⅜” bolts & four ½” bolts on each corner) and torque bolts to specs. (12 ft.-lbs.) (reverse of removal)
Thomas Nichols
crwdns2935283:011/04/19crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S4-G3, Kim Fall 2019 crwdns2935289:0University of Memphis, Team S4-G3, Kim Fall 2019crwdne2935289:0
UM-KIM-F19S4G3
crwdns2942667:0crwdne2942667:0 3,343
