Chevy 305 Engine Connecting Rod Bearing Replacement
  1. Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Connecting Rod Bearing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5/8 nuts on the connecting rod end cap using the 5/8 socket
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
  3. Chevy 305 Engine Connecting Rod Bearing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove and replace connecting rod bearing
    • Gently tap the end cap against the engine block or use a thin flathead screwdriver to remove it from the end cap.
    • Gently move the piston and rod down into the cylinder to replace the rod end bearing.
    • DO NOT PUSH THE PISTON OUT OF THE CYLINDER.
  4. Chevy 305 Engine Connecting Rod Bearing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
To reassemble your device, follow these instructions in reverse order. Torque the connecting rod cap nuts to 65ft.-lbs. Torque the oil pan bolts to 12ft.-lbs.
crwdns2935229:05crwdne2935229:0
Joey Barton
crwdns2935283:010/30/19crwdne2935283:0
397 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S4-G3, Kim Fall 2019 crwdns2935289:0University of Memphis, Team S4-G3, Kim Fall 2019crwdne2935289:0
UM-KIM-F19S4G3
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 3,157
