If your Chefman RJ38-V2-35 air fryer basket is not snapping into place properly, here’s how to replace the clips on the basket. This is a quick and easy guide with no special tools required.
Remove the basket from the air fryer.
Place the fryer basket on a flat surface.
Using the Phillips #1 screwdriver, remove four 5mm screws on the inside of the fryer basket (left two screws shown).
Separate the handle from the basket.
I need the plate inside the basket. The coating is coming off, Is it safe to use?
Where can I buy only the basket or just the plate? I need replacement but don’t seem to find the parts…
I need the plate inside the basket. Coating is coming off.
Where can I buy replacement rubber feet for the fryer basket plate? Mine came off and went down the disposal!! Are they required for proper heating and frying??
