Chef's Choice M115 Power Switch Replacement
  1. Chef's Choice M115 Power Switch Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chef's Choice M115 Power Switch Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Switch Replacement, Power Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chef's Choice M115 Power Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
  7. Chef's Choice M115 Power Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chef's Choice M115 Power Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
Hatontola malawo
crwdns2935283:009/17/15crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Fall 2015 crwdns2935289:0IUPUI, Team 3-3, Harley Fall 2015crwdne2935289:0
IUPUI-HARLEY-F15S3G3
What kind of switch should I replace the bad switch with? Is there one on Amazon ?
Ryan Frawley - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 467
