Charging Component on the Base Replacement
  1. Charging Component on the Base Replacement, Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
    • Use a screwdriver to remove all four 11mm Phillips #0 screws.
  2. Charging Component on the Base Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Charging Component on the Base Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
    • Opening the base may require exerting significant force as it is bound together tightly. This step can be dangerous.
    • The spudger is designed to make this step easier.
  3. Charging Component on the Base Replacement, Charging Component on the Base: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Charging Component on the Base Replacement, Charging Component on the Base: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the charging component towards the bottom of the grey, plastic, phone-shaped extrusion. It is composed of two metal pieces; each is fastened by a 5mm Phillips #0 screw.
    • Remove both 5mm Phillips #0 screws to release the metal pieces.
  4. Charging Component on the Base Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut the black and red wires to finish removal, and then solder your new replacement component.
    • For more help on soldering, please refer to the iFixit Solder and Desolder Guide.
Han Shih
crwdns2935283:009/29/16crwdne2935283:0
394 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-3, Harley Fall 2016 crwdns2935289:0IUPUI, Team 3-3, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S3G3
crwdns2935297:017crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 425
