This repair fixes a common issue on this device, after a few months of use the screen slowly gets dimmer before dying.
Remove both T2 screws
Slide off the plastic piece by lifting out and then up
Slide plastic and spring assembly off the rail
Insert a razor blade between the glass and the body
Keep going around the rim of the display until loose
Lift the display then battery up gently
Remove battery connector
Remove two P2 screws
Remove T2 screw
Liftoff metal shield
Liftoff both display connectors
Remove Display Assembly
Connect The new screen (basically step 6 in reverse)
Then perform the step 5 in reverse to put the metal shield back in
Reconnect battery connector
Put the battery back in place
Add a thin layer of E-6000 glue around the casing
Flip down the screen and remove any extra glue that squeezes out
Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
When the glue is fully cured remove the rubber bands
And voila you now have a repaired Fitbit Charge 3
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
