Char-Broil Grill Burner Replacement
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Char-Broil Grill Burner Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Char-Broil Grill Burner Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Char-Broil Grill Burner Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Char-Broil Grill Burner Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
Dan
crwdns2935283:010/01/17crwdne2935283:0
155 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team S5-G1, Galliah Fall 2017 crwdns2935289:0Michigan Tech, Team S5-G1, Galliah Fall 2017crwdne2935289:0
MTU-GALLIAH-F17S5G1
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 983
