Change the thermal breaker - Sterwins HC 150 Bars Cleaner
  1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removing the reel handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removing the reel handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before working on the device, make sure that the power plug is unplugged.
    • Pull the handle of the reel facing you to unclip it.
  2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 2 fixing screws of the housing
    • Remove the housing
    • Using a flathead screwdriver, remove the clip that holds the high pressure outlet fitting from the pump to the reel.
  3. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the connection facing you
    • Spread the 2 retaining bearings of the reel outwards.
    • Then remove the reel one side at a time.
  4. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 6 fixing screws marked with arrows.
    • Tilt the device on the front to access the last 2 fastening screws located under the product marked with arrows.
    • Then lay the device flat, and unscrew the plastic nut from the water inlet pipe.
  5. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the front panel upwards.
    • Return the product to its vertical position on its wheels.
    • Unscrew the screw indicated by the arrow to release the bearing from the reel to remove the pump outlet hose.
  6. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the mounting screw removed, slide the bearing as indicated by the arrow.
    • Then pull up to remove the bearing from the pipe.
    • Then remove the front panel.
  7. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the button facing you.
    • Unscrew the 2 screws as indicated in order to disengage the support.
    • Then unscrew the 6 screws and remove the cover to access the electrical connection.
  8. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the switch from its housing.
    • Disconnect the red power cable from the On/Off switch
  9. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Replacement of the circuit breaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a breaker.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0635crwdne2935297:0
crwdns2942667:0crwdne2942667:0 469
