Cen-Tech Seven Function Digital Multimeter Dial Replacement
    1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Position Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the meter face down, and the back panel and screws can be seen.
    2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
    3. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
    4. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 7mm Phillips screws holding the circuit board in place.
    5. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
    1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Locate Dial: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The dial is located in the central part of the device.
    2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Dial: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove dial from device by lifting upward.
      • Clean existing dial or replace if necessary.
      • Take care not to lose the small ball bearings.
Anna Kihm
crwdns2935283:010/13/14crwdne2935283:0
965 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-4, Benson Fall 2014 crwdns2935289:0Clemson, Team 2-4, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S2G4
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 102
crwdns2942667:0crwdne2942667:0 1,348
