Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
  1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
Anna Kihm
crwdns2935283:010/13/14crwdne2935283:0
956 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-4, Benson Fall 2014 crwdns2935289:0Clemson, Team 2-4, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S2G4
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,855
