Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
  1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Position Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate Dial: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The dial is located in the central part of the device.
  7. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Dial: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove dial from device by lifting upward.
    • Clean existing dial or replace if necessary.
    • Take care not to lose the small ball bearings.
  8. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate and Remove Ball Bearings: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate ball bearings. Carefully remove.
    • If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
    • If one or both ball bearings are missing, simply replace.
Anna Kihm
crwdns2935283:010/13/14crwdne2935283:0
956 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-4, Benson Fall 2014 crwdns2935289:0Clemson, Team 2-4, Benson Fall 2014crwdne2935289:0
CLEM-BENSON-F14S2G4
crwdns2942667:0crwdne2942667:0 2,154
