Ceiva LF2003 Main Circuit Board Replacement
  1. Ceiva LF2003 Main Circuit Board Replacement, Exterior Frame and Matting: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Main Circuit Board Replacement, Internal Plastic Screen Frame: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Main Circuit Board Replacement, Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ceiva LF2003 Main Circuit Board Replacement, Display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ceiva LF2003 Main Circuit Board Replacement, Display: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the display assembly from the device.
  12. Ceiva LF2003 Main Circuit Board Replacement, Main Circuit Board: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 7mm Torx T6 screws.
  13. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the three wires attaching the board to the power supply.
    • In the pictures, the wires are not actually desoldered.
  14. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder all the ribbon cable attachments from the board.
  15. Ceiva LF2003 Main Circuit Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circuit board from the device.
    • The picture shows the board still attached to the wires, but after desoldering, the board will be completely free from the device.
Casey Glasgow
crwdns2935283:001/26/14crwdne2935283:0
510 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-25, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 9-25, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S9G25
crwdns2942667:0crwdne2942667:0 195
