Cassida Counterfeit Detector Wire on Motor Replacement
  1. Cassida Counterfeit Detector Wire on Motor Replacement, Cassida Counterfeit Detector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber legs.
  2. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • All the parts disassembled.
  7. Cassida Counterfeit Detector Wire on Motor Replacement, Wire on Motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Get your solder iron and set it to 660 deg Fahrenheit.
    • We recommend using 60/40 solder.
    • Solid core wire is easier to use than standard.
  8. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the contact point for the wire by pressing the hot iron to the contact point until the solder flows and the cable can be pulled from the board.
    • Be careful not to make skin contact with the iron.
    • For more detailed help with soldering and desoldering, check out this handy guide for tips and best practices.
  9. Cassida Counterfeit Detector Wire on Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the solder looks like so. It should look like a small mountain.
    • The motor should now be able to be removed.
Michael Edwards
crwdns2935283:010/30/19crwdne2935283:0
197 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S2-G2, Kim Fall 2019 crwdns2935289:0University of Memphis, Team S2-G2, Kim Fall 2019crwdne2935289:0
UM-KIM-F19S2G2
crwdns2942667:0crwdne2942667:0 113
