Casio LK-170 Key Replacement
  1. Casio LK-170 Key Replacement, Key: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio LK-170 Key Replacement, Key: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio LK-170 Key Replacement, Key: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
    Nice tutorial here. Thank you for color coding the screw removal process.
    Sam Nead - crwdns2934203:0crwdne2934203:0
  2. Casio LK-170 Key Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio LK-170 Key Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
  3. Casio LK-170 Key Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio LK-170 Key Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will be able to pick up the white keys with your hands and remove them.
Samantha Baker
crwdns2935283:001/24/17crwdne2935283:0
443 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-2, Banghart Winter 2017 crwdns2935289:0Cal Poly, Team 13-2, Banghart Winter 2017crwdne2935289:0
CPSU-BANGHART-W17S13G2
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,582
