In this guide, we will be taking out the old SIM card and putting in a new one.
Slide the slider on the back of the phone to the free position.
Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
Pull the white battery tab upwards and remove the battery.
Using a spudger, gently open the metal tab up. Now, it is ready for you to insert the new SIM card.
That’s not a SIM card slot, that’s an SD card slot. You can’t install a SIM on the Casio G’Zone
i believe that is the memory card, not the sim card!
