Casio FX-115MS Keyboard Mat Replacement
  1. Casio FX-115MS  Keyboard Mat Replacement, Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS  Keyboard Mat Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
  4. Casio FX-115MS  Keyboard Mat Replacement, Motherboard and Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement, Motherboard and Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
  5. Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
  6. Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
  7. Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
  8. Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting from one corner of the keyboard mat, slowly peel the mat from the front plate and individual keys.
Fady Baskharoun
crwdns2935283:010/04/16crwdne2935283:0
274 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Nance Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Nance Fall 2016crwdne2935289:0
USFT-NANCE-F16S2G2
crwdns2942667:0crwdne2942667:0 567
