Casio FX-115ES PLUS Battery Replacement
  1. Casio FX-115ES PLUS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the calculator by pressing the [shift] button.
    • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
  2. Casio FX-115ES PLUS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio FX-115ES PLUS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio FX-115ES PLUS Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • Don't force the screwdriver on the screw, as it can strip the screw
  3. Casio FX-115ES PLUS Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover.
  4. Casio FX-115ES PLUS Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to take the battery out carefully.
    • Be careful when removing the battery to avoid any damage.
  5. Casio FX-115ES PLUS Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new 357 oxide button battery into the calculator.
    • Make sure that the + sign is at the bottom.
  6. Casio FX-115ES PLUS Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio FX-115ES PLUS Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio FX-115ES PLUS Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reattach the battery cover.
    • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
    • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
  7. Casio FX-115ES PLUS Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reset the calculator by pressing [ON].
    • Press the [Shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] [ALL] button option.
    • Press the [=] [yes] button to accept.
    • Press the [AC] key to reset completely.
You have successfully replaced a Casio FX-115ES PLUS battery
Rodrigo Lopez
crwdns2935283:001/23/23crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-1, Briggs Spring 2023 crwdns2935289:0CSU Los Angeles, Team 2-1, Briggs Spring 2023crwdne2935289:0
CSULA-BRIGGS-S23S2G1
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 3,697
