Casio Exilim EX-Z850 Flash Assembly Replacement
  1. Casio Exilim EX-Z850 Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your Phillips #00 screwdriver, remove the four screws on the side of the camera.
  2. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a Phillips #00 screwdriver, remove the four screws located on the bottom of the camera.
    • The bottom screws are longer than the top screws, so label accordingly for easy reassembly.
  3. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a Phillips #00 screwdriver, remove the four screws on the opposite side of the camera.
  4. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set bottom casing aside.
    • Prying open the camera from the casing could potentially damage the device, so open the casing slowly.
  5. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, gently pry apart the top casing from the camera.
    • Set the top casing aside.
  6. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pry the LCD screen off from the opening.
    • The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift up the LCD screen away from the camera.
    • Moving the screen could potentially damage the wire connecting it to the camera, so move the LCD screen slowly.
  8. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to slowly pry off LCD casing by lifting and moving it off the camera.
  9. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to flip open the connector holding the ribbon.
    • Gently pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the front of the camera, detach the ribbon from the connector.
  12. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the L shaped frame from the camera.
    • There is a yellow and orange wire connected to camera. Be careful not to pull them off.
    • At the bottom of the camera, the L-shaped frame is connected by two plastic bumps and a metal tab.
  13. Casio Exilim EX-Z850 Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two screws on the front of the flash assembly.
    • Remove flash assembly, and replace it with a new flash assembly.
Christian
crwdns2935283:001/28/11crwdne2935283:0
320 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-38, Regan Winter 2011 crwdns2935289:0Cal Poly, Team 4-38, Regan Winter 2011crwdne2935289:0
CPSU-REGAN-W11S4G38
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,003
