If the battery on the Casio Cassiopeia E-125 calculator is no longer holding a charge you may need to replace the battery. This guide will show you how to easily do so. There are no tools or extra knowledge needed. You will however need to purchase a new JK-210LT (1700mAh) Casio battery to replace the existing one.
This fix should only take five minutes to complete.
Flip the device over to the back side.
Slide the small switch on the back to "MAIN".
Slide the battery cover downwards.
Pull off the battery cover.
Pull the black tab to remove the battery.
