Casio CTK-501 Speaker Replacement
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio CTK-501 Speaker Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio CTK-501 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
  5. Casio CTK-501 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  6. Casio CTK-501 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
  7. Casio CTK-501 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
  8. Casio CTK-501 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely screw in the screws back into the original positions on the corner of the speaker.
Jimmy Winne
crwdns2935283:010/04/12crwdne2935283:0
578 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-16, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 9-16, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S9G16
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,774
