Casio CTK-501 Battery Connection Replacement
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio CTK-501 Battery Connection Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Casio CTK-501 Battery Connection Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
Jimmy Winne
crwdns2935283:010/04/12crwdne2935283:0
578 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-16, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 9-16, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S9G16
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 5,465
