Using a PH100 screwdriver, a set of wire cutters, and a soldering tool, the on/off switch can be replaced in the Casdon Dyson Ball.
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove batteries from the vacuum by pulling them out and away from the vacuum.
Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
Cut the two wires connected to the on/off switch using a set of wire cutters.
Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
Remove the on/off switch by pulling it away from the vacuum with your fingers.
Replace the faulty on/off switch with the new on/off switch.
Great instructions but where can you purchase the on of switch and what is the part number?
