Casdon Dyson Ball Disassembly
  1. Casdon Dyson Ball Disassembly, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Disassembly, Casdon Dyson Ball Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove beads from the container.
Seldon Price
crwdns2935283:011/07/17crwdne2935283:0
612 crwdns2915208:0crwdne2915208:0
IUPUI, Team S3-G5, Harley Fall 2017 crwdns2935289:0IUPUI, Team S3-G5, Harley Fall 2017crwdne2935289:0
IUPUI-HARLEY-F17S3G5
How do I get the handle out once assembled?
Carie McClendon - crwdns2934203:0crwdne2934203:0
Den Griff bekommt man nach dem Einstecken offensichtlich nicht mehr entfernt.
Das Batteriefach bietet keinen Zugang um die Befestigungsraste zu lösen.
Fraglich ob man an die Befestigungsraste kommt, wenn man das Gerät quasi komplett auseinanderschraubt.
Bei eBay wird ein gebrauchtes Gerät angeboten, bei dem der Griff nicht mehr hält, der Besitzer hat vermutlich versucht den Griff mit Gewallt herauszuziehen und dabei die Befestigungsraste abgebrochen.
Das Gerät lässt sich mit dem nicht mehr entfernbaren Griff nicht mehr im Originalkarton verpacken und versenden.
In meinen Augen eine mangelhafte Konstruktion.
"Wie bekomme ich den Griff nach der Montage heraus?"
NichtCheck -
How does the handle come out in English what language was that? There is no videos on how to remove the handle or even get the little pellets to spin again
steven welch -
The fan to make the beads jump around no longer works….is there. Separate battery for that?
Kathy - crwdns2934203:0crwdne2934203:0
Nein, der "Ventilator" für die Perlen wird mit den Batterien betrieben.
Ich würde davon ausgehen, dass der Ventilator bei Ihnen defekt ist, sofern er nicht unwahrscheinlicher Weise durch eingeklemmte Perlen blockiert ist.
NichtCheck -
crwdns2936753:030crwdne2936753:0 114
crwdns2942667:0crwdne2942667:0 14,711
