By using the PH00 screwdriver, this guide will show how to remove the batteries from the Casdon Dyson Ball.
Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
Remove batteries from the vacuum by pulling them out and away from the vacuum.
I was looking for the kind of Batteries needed-this guide is really good but never says what type of Battery for the Dyson Ball;
Might be something to add??
C batteries.
einst -
Thank you! Requires 4 (four)”C” batteries yay!
