Carrier 14 Seer Heat Pump Capacitor Replacement
  1. Carrier 14 Seer Heat Pump Capacitor Replacement, Capacitor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement, Capacitor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement, Capacitor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Caution: Use a non-contact voltage tester or a multimeter to make sure that the breaker is not electrically charged. If you do not have access to a multimeter, tap the breaker box with the back of your hand. If you use the palm of your hand and there is a charge, your hand will clench, making it hard to remove your hand from the box.
    • Turn off your heat pump unit's breaker.
  2. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the emergency shutoff switch by firmly grasping it and pulling it out.
  3. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 5/16 nut driver to remove the single bolt and remove the cover by sliding it downwards.
  4. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an insulated screwdriver, tap two of the capacitor's ports at a time to remove any excess charge.
  5. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and remove the capacitor from the unit.
  6. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace and plug in the new capacitor.
    • The brown wire will go to the Fan port.
    • The yellow wires will go to the C port.
    • The blue wire will go to the Herm port.
    • As long as the wires are on the correct port, it does not matter which connector you use.
  7. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the cover on your unit by sliding it upwards and replacing the single bolt.
  8. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Plug in the Emergency Shutoff switch.
    • Make sure that the connectors are on the lower side.
  9. Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Carrier 14 Seer Heat Pump Capacitor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn on the breakers.
Replacing the capacitor should fix your air conditioner. Please note that the unit will take some time to charge the capacitor before starting up again.
Caleb Gross
crwdns2935283:009/19/23crwdne2935283:0
178 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 22-4, Watkins Fall 2023 crwdns2935289:0Austin Community College, Team 22-4, Watkins Fall 2023crwdne2935289:0
AUSTINCC-WATKINS-F23S22G4
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 1,487
