The quadrocopter will not fly correctly if a rotor blade is damaged or installed wrong. This guide will show you how to remove any of the quadrocopter’s four rotor blades.
Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
Lift the screw out and set it aside.
Lift the rotor blade out.
Hi. How i can buy the rotor blade
Ainul Abd Rahim - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
