Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement
  1. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Power Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Battery Tray: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
  6. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement, Blender Assembly P/N 16358A: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the rear panel is installed, remove the high and low pressure oxygen fittings from the rear panel using your 3/4" wrench. NOTE: the high pressure fitting is located above the low pressure fitting
    • If the rear panel is installed, disconnect the 40-pin ribbon cable from the SVGA out PCB.
  7. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the front panel is installed, disconnect the green oxygen nebulizer tube.
    • Disconnect the:
    • -J301, 12-Pin Connector to J301 on the main PCB
    • From the blender PCB
  8. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom strip ambient air inlet filter by pinching and pulling it out.
  9. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Phillips pan-head screws on the right side of the rear panel.
  10. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The assembly should now be free to remove. As you remove the unit use your needle-nose pliers to disconnect the oxygen diffuser tube as you remove the blender assembly.
  11. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the exhalation valve assembly is installed, disconnect:
    • J3 [2-pin (blue connection)]
    • To the oxygen inlet solenoid on the blender assembly.
    • J4 [2-pin (red connection)]
    • To the Nebulizer solenoid assembly on upper rear of blender.
    • For Instillation follow steps in reverse order.
    • Disconnect the main wire harness connector at P2 on the Turbine Driver PCBA
  12. Cardinal Health Vela Ventilator Turbine/Muffler Assembly P/N 16349 Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 Phillips pan-head mounting screws.
    • Disconnect the gray silicone intake and output elbows by gently pulling them out from the muffler tubes.
    • The Turbine/Muffler Assembly should now be free to lift off the manifold base.
    • Gently pull up on the elbows to remove
    • To Install P/N 16350 "Turbine/Muffler Assembly" repeat the steps in reverse order.
Tanner Hillman
crwdns2935283:004/10/20crwdne2935283:0
370 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G22, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G22, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G22
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 371
