Cardinal Health Vela Ventilator Left Panel Replacement
  1. Cardinal Health Vela Ventilator Left Panel Replacement, Power Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the two Phillips pan-head screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Left Panel Replacement, Cardinal Health Vela Ventilator Top Cover Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Left Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Cardinal Health Vela Ventilator Left Panel Replacement, Battery Tray: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to unscrew the 4 Phillips pan head screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Left Panel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
    • Remove the two Phillips countersink at the rear of the panel.
    • Remove the Phillips countersink in the upper front of the panel.
    • The panel is now free and can be lifted from the device.
    • To install the left panel follow these steps in reverse order.
Tanner Hillman
crwdns2935283:004/10/20crwdne2935283:0
370 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G22, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G22, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G22
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 126
