Cardinal Health Vela Ventilator Exhalation Valve Body Replacement
crwdns2931587:0crwdne2931587:0
  1. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement, Exhalation Valve Body: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the two Phillips #0 screws at the top of the plug guard.
    • Remove the plug guard and unplug the ventilator.
  2. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Phillips #0 screws on the back side of the ventilator.
  3. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all six small side panel screws along the bottom of each side of the top cover with the same screwdriver.
    • Slide the top cover towards the back side of the ventilator to remove it.
  4. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips #0 screwdriver to unscrew the four Phillips screws positioned on each side of the battery tray.
    • Lift the battery tray out of the ventilator.
    • Caution: The wires connecting the batteries to the ventilator will still be connected so lift the battery tray carefully.
  5. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the batteries from the ventilator by pulling apart the Battery Connector.
  6. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips countersink screws from the right side of the rear panel.
  7. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single Phillips countersink screw in the upper front of the right panel.
  8. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single Phillips screw in the lower center of the right panel.
  9. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift out the panel and the power PCB. Lay the panel flat and make the following disconnections:
    • Remove the 2 Phillips countersink screws at the rear of the left panel.
    • Remove the 1 Phillips countersink screw in the upper front of the left panel.
    • Lift out the left panel.
    • Disconnect the following from the main PCB:
    • JP2 40-pin ribbon cable to JP1 on the SVGA out PCB
    • J301 12-pin to J301 on the blender PCB
  10. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the green oxygen nebulizer tube
    • Remove the 2 Phillips pan-head screws behind the front panel at the lower left and right.
    • Disconnect the 1/8” silicone tube #4 from P2 on the exhalation differential transducer.
    • Disconnect the 1/8” silicone tube #5 from P1 on the exhalation differential transducer.
    • Disconnect the 1/8” silicone tube #1 from the turbine.
    • Disconnect the 1/16” silicone tube from the front ports of the turbine outlet auto-zero solenoid that goes to the main tubing harness.
    • Disconnect the 1/16” silicone tube from the turbine inlet auto-zero solenoid that goes to the turbine.
    • Disconnect the 1/16” silicone tube from the airway pressure auto-zero solenoid that goes to the exhalation valve receptacle.
  11. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the following from the FIO2 monitoring PCB:
    • J2 2-pin (clear conn.) to oxygen sensor
    • J3 2-pin (blue conn.) to oxygen inlet solenoid on blender assembly
    • J4 2-pin (red conn.) to nebulizer solenoid assembly on upper rear of blender
  12. Cardinal Health Vela Ventilator Exhalation Valve Body Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two Phillips pan-head screws on the valve cover.
    • Lift out the exhalation valve assembly.
crwdns2935103:0crwdne2935103:0
Ethan Nikcevich
crwdns2935283:004/07/20crwdne2935283:0
649 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S11-G22, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S11-G22, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S11G22
crwdns2942667:0crwdne2942667:0 419
