In most vehicles, a small stopper holds the seat belt buckle in place. Sometimes the stopper comes off or breaks, allowing the buckle to slide down. This simple guide demonstrates how to replace the seat belt stopper so you can drive safely without the inconvenience of the buckle sliding down after each use.
Use a cloth to wipe away any debris from the area.
Find the existing hole for the seat belt stopper or choose a different location that is better for you.
Separate the replacement stopper if it has come assembled.
Push the side of the seat belt button with the needle or point into your desired location.
Take the other half of button stopper and slide it onto the pin on the other side of the belt.
Fasten the two parts of the button together and squeeze for a secure fit.
Check the position of the replacement stopper for a comfortable fit.
Now you can use the seat belt buckle without it falling down!
Changing your positioning of replacement can be used to your liking.
