Capresso PerfecTea 260 Dial Replacement
  1. Capresso PerfecTea 260 Dial Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, take the base of the device and flip it over.
  2. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the wire going into the side of the motherboard
  5. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard out of the device
  7. Capresso PerfecTea 260 Dial Replacement, Control System: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement, Control System: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7.5mm Phillips #2 screws from the metal frame.
    • Remove the frame from the assembly.
  8. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
    • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
  9. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the cable that attaches the small computer chip to the heating element connections.
    • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
    • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
    • Push the latch off the tab with the spudger.
    • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
  10. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the two computer chips that connect the two yellow wires to the temperature controls.
    • Remove the four 5 mm Phillips #1 screws.
    • Remove the two computer chips from their places.
    • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
  11. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Find the computer chip over the dial.
    • Remove the three 6mm Phillips #2 screws.
    • Remove the computer chip.
    • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
    • Keep the plastic frame on the bottom of the chip attached.
  12. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the four cables on the left side of the chip.
    • Remember which cable goes to which plug.
  13. Capresso PerfecTea 260 Dial Replacement, Dial: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement, Dial: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement, Dial: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6 mm Phillips #1 screws from the black dial base plate.
    • 6 mm Phillips #1 screws
    • Remove the black dial base plate, metal spring, LED tube, and the actual dial.
  14. Capresso PerfecTea 260 Dial Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Capresso PerfecTea 260 Dial Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 7.5 mm Phillips #2 screws from the dial collar.
    • 7.5 mm Phillips #2 screws
    • The dial collar will then come away from the base.
Olivia Morgan
crwdns2935283:004/14/15crwdne2935283:0
Cal Poly, Team 6-17, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 6-17, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S6G17
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 295
