If you need to replace the timer/on switch, follow this guide. The timer/on switch is essential to how long the coffee beans take to turn into coffee grounds. For this guide, you will need the Torx Security T10 Bit Screwdriver, the extension bit, and a soldering iron.
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Twist the top burr to the left counter clockwise.
I own a model 560. Removing the grinder requires a Torx 20, which is in the center of the top burr. If used, the screw is coated with coffee grinds.
Flip entire device upside down.
Remove two rubber coverings on the back of the device.
Remove four 11.59mm T10 screws.
T8 Torx screws. The two screws towards the front of the machine are below those circled in red in the picture.
My housing is plastic, and was just held on by clips holding the outer part to the base, I gently pried the housing away and lifted the housing off. It’s a Capresso model 560
Mine is as well. I tried digging the “rubber washers” out but it was only scratching plastic.
There are 5 areas you can slide a slim flathead into and gently wiggle to get the casing to slide out from the base. Be firm yet gentle.
Lift the metal outside casing off the black base.
Flip the outside casing forward so you have access to the inside of it.
What about the hard black plastic gasket that fits under the inside lip of the outer metal case?
It sits between the outer metal case & the black plastic flat ring. Please describe how to reassemble that part.
Remove one 11.59mm T10 screw.
Let the green wire fall, or place somewhere so it doesn't get in the way.
T8 Torx screw.
My unit has a plastic case and a two-prong plug, so there is no ground wire.
Remove the time/on switch by pulling upwards.
Strip the two wires of their black covering connecting them to the black box.
Solder the two cords holding in the blue and white wire in the black timer box.
crwdns2947412:07crwdne2947412:0
do you know where I can get a new black timer box?
Where can I purchase a timer/on switch?
Same question here, where can I buy this part?
Just piling on,has anyone found where to buy the Timer switch?
Same, looking for part number and/or where to buy the timer dial.
For those interested, I took my Capresso apart and it's a "Faucigny Instruments MI3 Swtich Timer", information on it here: https://www.fcsgroupe.com/en/component/s...
However, I'm having trouble finding any to purchase.
On another note, on my Capresso, it seems like the issue wasn't the timer, but the plastic dial to turn the timer had broken inside where it slides over the spindle of the timer gear. The plastic collar on the dial had split, so was no longer gripping the spindle to turn it. I repaired it with some plastic cement. I used an elastic band wound very tightly around it to hold it in place while it dried, and just left that on there when I put the dial back on to hopefully give it some extra support.
It has held through a few uses, but in my experience plastic repairs of that type that have to deal with pressure don't tend to last very long, but here's hoping.
Sorry, but this is useless as the timer switch is not available
