This guide will show a step by step explanation to how to fix the speakers of the CanonZR70MC that controls all sound coming from the camcorder. This is necessary because the will allow you to gain access to the speakers component and help replace in the future. While going through this guide, you should handle the device with care and designated locations for the parts.
Unscrew the 3.35mm screw.
Turn the ZR70MC so that you can see the bottom of the camcorder.
Unscrew the 3.35 mm located in the top left portion of the camera.
Turn the camera on the side and remove the cover for the audio inputs. There is a 2.65 mm screw located behind the cover.
Remove the 2.65 mm screw.
Remove the cover located on the front of the camcorder and remove the cover by pulling on the bottom groove.
Locate and remove the two 3.35 mm screws.
Turn the camcorder so that the bottom is facing up and open the tape cassette compartment.
There is one 3.35 mm screw located under the tape cassette panel on the front left side of the camcorder. Remove the screw.
Now that all of the screws are removed, remove the front panel by gently pulling on the front panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to gently pull the speaker wire from the main body of the camcorder.
Pull the front panel completely away from the main body of the camcorder.
Take the front panel and remove the three 2.75 mm screws from the metal plate.
Remove the metal plate. This metal plate protects the black speaker holder.
Remove the black speaker holder from the front panel. This holds the individual speakers.
Remove the individual speakers from the black speaker holder.
