These simple steps will help you replace the strap handle of your Canon Vixia HF S10 camcorder.
Flip the camcorder upside down and remove the four 2.5 mm Phillips #00 screws from the bottom of the camera and two 2.5 mm screws from the top of the camera.
Unhook the strap.
Using a plastic opening tool, outline the edges.
Remove the plastic casing.
Remove the single 2.5 mm Phillips #00 screw securing the silver plate.
Using your fingers, remove the silver plate.
Remove the strap to have it replaced.
