The wrist strap aids the user in keeping the camera secure while recording. It is recommended that you remove it before removing the side panel.
Position the camcorder so that the wrist strap is facing you.
Locate the loose end of the strap.
Gently pull on the loose end to separate the Velcro.
Locate the "slot" on bottom right corner of the camcorder where the strap loops through.
Pull the strap through the loop.
Pull the strap through the leather cushion.
Pull the strap through the slot on the left side of the camcorder.
