Canon Vixia HF R600 Power Button Replacement
  1. Canon Vixia HF R600 Power Button Replacement, Handstrap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement, Handstrap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Power Button Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Power Button Replacement, Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement, Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Power Button Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement, Speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 4mm Phillips JIS#00 screw on the right side of the camera.
    • Use the plastic opening tool to undo the bronze ribbon connector.
  8. Canon Vixia HF R600 Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 4mm Phillips JIS#00 screw located on the top of the camera near the battery connection.
    • Pull the plastic casing away from the camera. The speaker and power button are housed in this casing.
  9. Canon Vixia HF R600 Power Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 5mm Phillips PH#00 screws holding the speaker bracket in place.
    • Remove one more 5mm screw below the power button.
  10. Canon Vixia HF R600 Power Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the speaker out of the casing.
  11. Canon Vixia HF R600 Power Button Replacement, Power Button: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Power Button Replacement, Power Button: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of tweezers, gently push in the red tabs of the power button.
    • Pull the power button out of the camera casing.
Brian Luna
crwdns2935283:002/10/16crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-4, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-4, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G4
crwdns2942667:0crwdne2942667:0 496
