Canon Vixia HF R600 LCD screen Replacement
  1. Canon Vixia HF R600 LCD screen Replacement, Handstrap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement, Handstrap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 LCD screen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 LCD screen Replacement, Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement, Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
    Keep track of what screw goes where. There are several sizes and thread pitches to keep track of!
    Tim Doehler - crwdns2934203:0crwdne2934203:0
  5. Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 LCD screen Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD display from the camera body.
    The LCD screen cannot be removed on the R600 without removing two screws found on the inside of the body. To get to those screws you have to remove the entire "insides" of the camera.
    David Green - crwdns2934203:0crwdne2934203:0
    Can you replace the touch screen on the R500 by removing the 2 screws on the hinge side of the display or do you have to remove the entire insides of the camera
    sverlander - crwdns2934203:0crwdne2934203:0
  8. Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the display hinge to reveal two 4mm Phillips #00 screws.
    • Before removing, use the plastic opening tool to pry apart the plastic hinge cover.
    • Remove the cover.
  9. Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 4mm Phillips #00 screws.
    • Pull the LCD display back cover to reveal the motherboard covering the screen.
    • Remove one more 4mm Phillips #00 screw.
  10. Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 LCD screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the screen protector away from the LCD display.
    • Use a plastic opening tool to lift the ribbon connector tab.
    • The LCD display can now be replaced!
Brian Luna
crwdns2935283:002/10/16crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-4, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-4, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G4
Where did you find the replacement LCD screen at? Specifically I am looking for the Vixia HF M41A version
Jeff Onsrud - crwdns2934203:0crwdne2934203:0
I can’t find the replacement lcd for my model canon vixia hf R600, can you point me in the right direction?
Seth Flake - crwdns2934203:0crwdne2934203:0
Gotta hf r800 and need screen, any ideas where?
Sean - crwdns2934203:0crwdne2934203:0
Very nice step by step guidance. Where can I find the Replacement lcd screen for Canon Vixia HFR 600 camera. Will appreciate that!
Thanks!
shelaindrab - crwdns2934203:0crwdne2934203:0
I have a Canon Vixia HF R52, and with all my research it looks like all of these are the same LCD: HF-R52, HF-R82, HF-R600.....and maybe even the HF-R48, and HF-R406, and HF-R706.
pe.labs - crwdns2934203:0crwdne2934203:0
I think this is it: https://www.aliexpress.us/item/325680404...
But, I'm about to purchase it, and try it.
crwdns2942667:0crwdne2942667:0 2,517
