Canon Vixia HF R600 Camera Lens Replacement
  1. Canon Vixia HF R600 Camera Lens Replacement, Handstrap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement, Handstrap: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Camera Lens Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Camera Lens Replacement, Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement, Casing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
    Keep track of what screw goes where. There are several sizes and thread pitches to keep track of!
    Tim Doehler - crwdns2934203:0crwdne2934203:0
  5. Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement, Camera Lens: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one 5mm Phillips PH#00 screw from the top of the camera.
    • Pull away the plastic shutter casing; this contains the microphone.
    • Using the plastic opening tool or something similar, carefully disconnect the white 4 pin connector to remove the shutter casing.
  8. Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Vixia HF R600 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 5mm Phillips PH#00 screws surrounding the camera lens.
    • Pull the lens off of the camera and replace.
Brian Luna
crwdns2935283:002/10/16crwdne2935283:0
483 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-4, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-4, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G4
I think you need a part, the lens..... Which is what I also need, which is why I'm here..... Now, if I could just figure out where to get a lens your tutorial would be helpful.
dannyknappy - crwdns2934203:0crwdne2934203:0
Mi camara canon r600 le han salido manchas negras en el lente . Alguien sabra como quitarselas?
**WONS MIX** - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 704
