Canon Selphy CP1200 Motherboard Replacement
  1. Canon Selphy CP1200 Motherboard Replacement, LCD/Buttons: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
    I have one but the lcd have Been broken can you give me the number of the lcd please
    Mrgames-kw - crwdns2934203:0crwdne2934203:0
  5. Canon Selphy CP1200 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the fan cable from the motherboard.
    Bonjour,
    Pourriez vous me dire sur quel site acheter la carte mère de remplacement ?
    Merci d'avance
    Stéphanie Possetto - crwdns2934203:0crwdne2934203:0
  6. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 3mm PH000 screws from the motherboard.
    As at this point the whole printmechanism-motherboard assembly is already loose in the case, you can also consider taking out the whole thing completely before removing these screws. It is much easier to remove the cables at the bottom when you have a bit more space. You have to bend the plastic case a bit so the USB ports are free, but other than that you should have not have a problem.
    (do step 10 first though, if possible)
    Joffrey Wallaart - crwdns2934203:0crwdne2934203:0
  8. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
W Sherer
crwdns2935283:001/16/19crwdne2935283:0
647 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G3, Crawford Winter 2019 crwdns2935289:0Eastern Washington University, Team S1-G3, Crawford Winter 2019crwdne2935289:0
EWU-CRAWFORD-W19S1G3
Hi, where can I buy a new motherboard for the Selphy CP 1200 online ?
Ariinui Tama - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,435
