Canon SX40 HS camera Flash Cover Replacement
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon SX40 HS camera Flash Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
To reassemble your device, follow Steps 1-4 in reverse order.
John Bui
crwdns2935283:003/26/15crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-7, Cichon Spring 2015 crwdns2935289:0UMass Dartmouth, Team 7-7, Cichon Spring 2015crwdne2935289:0
UMASSD-CICHON-S15S7G7
How to disconnect wires from front cover to remove it.
Pete Gubbels - crwdns2934203:0crwdne2934203:0
Has anyone tried to remove the front cover from their sx40?
Mine has a bundle of 4 wires going to some sensor below where the flash is. Looks like there’s a clear plastic sensor there but I can’t figure out how to disconnect them.
crwdns2942667:0crwdne2942667:0 947
