Canon Rebel T5i SD Card Door Replacement
  1. Canon Rebel T5i SD Card Door Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
  2. Canon Rebel T5i SD Card Door Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the left rubber grip using a plastic opening pick.
    • Underneath the grip, remove the following screws:
    • Four M1.7x5.0mm T6 Torx screws
    • On the right side of the camera, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
    • One M1.7x3.5mm JIS #000 screw
  3. Canon Rebel T5i SD Card Door Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom of the camera, remove the following screws:
    • One M1.7x6.0mm JIS #000 screw
    • Two M1.7x3.0mm JIS #000 screws
    • On the back of the camera, remove the following screws:
  4. Canon Rebel T5i SD Card Door Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening pick, partially peel up the top of the back rubber grip.
    • Carefully begin lifting the back cover up away from the camera body.
    • Do not lift it all the way off. There is still a ribbon cable attaching the back cover to the main PCB board.
    • Use a plastic spudger to gently pry off the ribbon cable.
    • Use a plastic spudger to gently pry off the other cable connecting the back cover to the camera.
    • The connector tab sticks out slightly on each end of the connector, which gives you a good spot to pry the connector off.
  5. Canon Rebel T5i SD Card Door Replacement, SD Card Door: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Rebel T5i SD Card Door Replacement, SD Card Door: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the inside of the SD card door, remove the following screws holding the metal plate in place:
    • Two JIS #000 screws
    • Using the end of a screwdriver or another hard tool, push the metal SD card door hinge upwards
    • One the hinge is fully removed, the SD card door can be pulled off the camera.
crwdns2935103:0crwdne2935103:0
Zephosk
crwdns2935283:009/26/24crwdne2935283:0
4.792 crwdns2915208:0crwdne2915208:0
crwdns2935297:029crwdne2935297:0
LGBTQ Technicians crwdns2935289:0LGBTQ Technicianscrwdne2935289:0
Community
crwdns2931471:040crwdne2931471:0
crwdns2935297:068crwdne2935297:0
crwdns2942667:0crwdne2942667:0 83
