User will need PH00 screwdriver and plastic pry tools for this replacement guide.
Rotate the camera to expose the underside of the camera.
Slide the rounded rectangle tab to the left to release the battery cover.
Push the small orange tab forward to release the battery (Battery is ready for removal).
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
Using the plastic pry tool, remove the back cover from camera.
