Canon Powershot SX30 IS LCD Replacement
  1. Canon Powershot SX30 IS LCD Replacement, LCD Panel Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
  6. Canon Powershot SX30 IS LCD Replacement, LCD Panel Front Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 2mm screw on the outer edge of the panel
  7. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 3mm screw on the inner edge of the panel. This is easily done by rotating the screen to be perpendicular to the body of the camera, but be careful not to damage the wires or the circuit board.
    • The panel will fall right off
  8. Canon Powershot SX30 IS LCD Replacement, LCD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement, LCD: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use spudger to remove the gold ribbon wire
    • This is easily done by lifting up the small black lock that holds the ribbon wire in place
  9. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the second ribbon wire
    • This is best done by grasping at the base and pulling straight away from the circuit board
  10. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot SX30 IS LCD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the LCD screen out of the metal casing.
    • This is especially easy if you run the plastic opener along the bottom of the case
    • When the screen pops out, replace it with the new one.
  11. Canon Powershot SX30 IS LCD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the wires back on the circut board
    • The large one can be replaced by placing the wire gently in the slot and then pushing the lock into place
    • The smaller wire should be fed back into the board using tweezers to prevent bending at the edge.
    • To finish, follow the previous steps in reverse order to put everything back where it belongs
Ellis DeVoe
crwdns2935283:004/14/15crwdne2935283:0
580 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-12, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 5-12, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S5G12
crwdns2947412:08crwdne2947412:0
Great instructions. Took me less time than estimated. Thanks
frankypianoforte - crwdns2934203:0crwdne2934203:0
Thank you. Very clear instructions.
Barbara Allred - crwdns2934203:0crwdne2934203:0
Hi, I just bought a display lcd screen. but it has only one ribbon, not have the little tiny one. What should I do?
Sadia Afrin - crwdns2934203:0crwdne2934203:0
Was any body able to find the replacement screen with 2 ribbon cables for the Canon SX30 IS having back light?
If so please share I’m in need of one for my camera.
Thanks
lukebuser - crwdns2934203:0crwdne2934203:0
I’m also interested in where to buy the “two ribbon” display version. I just bought the wrong one with one ribbon and recognized that the “one ribbon” version ribbon also is a bit wider than the “two ribbon” version. I guess they changed the design and integrated the two ribbons into one (for assembly purpose I think).
washmann -
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 3,387
