Taking off the outer panels of your camera, disconnecting and replacing the mini USB port.
            Remove screw attaching the Mini USB Cover to the top of the camera body.
            Remove Mini USB Cover, by pulling it away from the camera body.
            Detach electronic ribbon and Mini USB Port using a plastic opening tool to pull the ribbon off.
            You can now replace the Mini USB Port.
