Canon Powershot ELPH 100 HS Speaker Replacement
  1. Canon Powershot ELPH 100 HS Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Speaker Replacement, Memory Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement, Memory Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement, Memory Card: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
  4. Canon Powershot ELPH 100 HS Speaker Replacement, Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  5. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  6. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  7. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  8. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  9. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  10. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
  11. Canon Powershot ELPH 100 HS Speaker Replacement, Speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn on soldering Iron.
  12. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the tabs surrounding the power button on the housing of the camera.
    • Be careful not to break the wires that connect the housing to the body of the camera.
  13. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the battery is removed.
    • Cut the wires half way between the microphone and body of camera.
    • Leave 25mm of wire on the speaker when cutting the wire
  14. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip the ends of the newly cut wires.
    • Expose only 2 mm of bare wire.
  15. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3.1mm screw holding speaker to the housing.
    • Remove the two clips and the metal cover will be released
    • When you remove the metal cover the spring will shoot out.
    • Take note of the spring and its orientation, it will need to be re-installed later
    • Image of the spring
  16. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, grab the wires to pull the speaker from the plastic housing.
    • Use force as the speaker is glued to the housing.
  17. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Test the heat of the soldering iron by touching it to the tip of a paperclip.
    • If the tip of the paperclip melts, the iron should be ready.
    • If you have never used a soldering iron before, please consult the tutorial in the description of this guide, or watch the following video: How To Solder Or Soldering Techniques.
  18. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the red wire to the right terminal, and the black wire to the left terminal.
    • Do not apply force to the speaker wires during this step. If the wires break, you will need to re-solder them.
  19. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the speaker back in it's housing.
  20. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the metal cover over the speaker.
    • Do not attach the screw.
  21. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the corner of the metal cover and slide the spring in so it rests around the screw hole.
    • After the spring is around the screw hole post, replace the screw so that the cover stays in place.
  22. Canon Powershot ELPH 100 HS Speaker Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reattach the speaker housing to the rest of the camera, make sure the pins and clips are aligned.
To reassemble your device, follow the case disassembly guide in reverse.
Jacob
crwdns2935283:003/17/15crwdne2935283:0
570 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-10, Lauer Spring 2015 crwdns2935289:0Michigan Tech, Team 1-10, Lauer Spring 2015crwdne2935289:0
MTU-LAUER-S15S1G10
crwdns2942667:0crwdne2942667:0 973
