This guide will show you how to remove your camera's memory card when you need to transfer pictures. If the memory card is malfunctioning in any way, you can also use this guide to install a new memory card.
            Locate the battery cover on the bottom of your camera.
            Slide the tab to the right to open the battery cover.
            Flip the battery cover open.
            Using your fingers, slide the battery out of the camera.
            Push down on the memory card until it clicks and releases.
            Pull up on the memory card to remove it.
my internal card reader hardware is not functional
can i replace it somehow
