A common issue with this camera is a cracked display screen or the screen not showing the picture, meaning it is damaged. This guide will walk you through the process of replacing the screen.
            Locate the battery cover on the bottom of your camera.
            Slide the tab to the right to open the battery cover.
            Flip the battery cover open.
            Using your fingers, slide the battery out of the camera.
            Push down on the memory card until it clicks and releases.
            Pull up on the memory card to remove it.
            Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
            Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
            Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
            With the screen still facing you, rotate the camera 180 degrees.
            Use the Philips #00 screwdriver to pry open the charging port cover.
            Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
            Remove both 3.1 mm screws using the Phillips #00 screwdriver.
            Turn the camera so the bottom is once again facing up.
            With the battery door still open, use a spudger to remove the cover from the front of the camera.
            Once the entire front cover has been released carefully pull it off.
            Just like Step 4-6 , carefully use the Spudger to remove the back cover.
            Remove the 3.1mm screw on the top-right side of the LCD display screen.
            Use the spudger to carefully separate the screen from the frame.
            Use the spudger to lift up the latch on the zero insertion force connector (ZIF).
            Slide the now free ribbon cable from the connector.
            Holding the display screen, gently pull the ribbon cable out through the frame of the camera.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using tweezers, carefully remove the ribbon cable from the connector shown.
            The display screen should now be free.
