Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot ELPH 100 HS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot ELPH 100 HS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Lillia
crwdns2935283:003/17/15crwdne2935283:0
267 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-10, Lauer Spring 2015 crwdns2935289:0Michigan Tech, Team 1-10, Lauer Spring 2015crwdne2935289:0
MTU-LAUER-S15S1G10
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - crwdns2934203:0crwdne2934203:0
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
What if the battery cover (gray tab) is broken?? I accidentally ripped it off.
Jade - crwdns2934203:0crwdne2934203:0
I have this same issue did you ever find a solution ?
amirah -
crwdns2942667:0crwdne2942667:0 2,272
