Canon Powershot A95 Flash Unit Replacement
  1. Canon Powershot A95 Flash Unit Replacement, Flash Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement, Flash Unit: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement, Flash Unit: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Have a small Phillips-head screwdriver and extender, an opening tool, and a soldering iron to complete the following steps.
    • Keep the screws organized and separated as you remove them.
  2. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the memory card slot on the far right with the screen facing toward you.
    • Remove the memory card.
  3. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screen facing toward you, the battery slot can be found under the right side of the camera.
    • Remove all batteries and leave the slot open.
  4. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two screws to the right of the battery slot.
    • Take the #00 Phillips-head screwdriver and remove the two screws.
  5. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Inside the battery slot, there are another 3 screws located at the very bottom of each slot.
    • To reach these screws and remove them, attach the screwdriver extender to the #00 Phillips-head screwdriver.
  6. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the base of the battery flap, there are 2 screws located next to the hinges of the opening.
    • Remove both screws.
  7. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pry tool, pry the top of the camera open.
    • Be sure not to apply too much force and damage the wires under the lid.
    • The top should dangle loosely from the camera and not be fully detached.
  8. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the top is loose, locate the 2 screws near the AV outlet.
    • The removal of the 2 screws will allow you to remove the plastic AV covering.
    • Once the AV cover is removed, there will be 1 more screw left to remove.
  9. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the pry tool, gently remove the front cover of the camera in order to expose the flash and the lens.
  10. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the black film under the flash unit and remove the screw holding it in place.
    • Once the screw is removed, gently wiggle the flash out of place without damaging any internal parts.
  11. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Canon Powershot A95 Flash Unit Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There will be a second black film which is covering the flash wires.
    • Remove the film to reveal the wires.
  12. Canon Powershot A95 Flash Unit Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the second film is removed and has revealed the flash wires, proceed to unsolder the necessary wires in order to detach the flash.
    • Take the new flash and solder it where the old one was removed.
To reassemble, follow the disassemble steps in reverse order.
Amber
crwdns2935283:002/12/13crwdne2935283:0
3 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-4, Buehl Spring 2013 crwdns2935289:0Ohio State, Team 1-4, Buehl Spring 2013crwdne2935289:0
OSU-BUEHL-S13S1G4
crwdns2942667:0crwdne2942667:0 1,024
